Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool AWO/D 049 issues!!
- This topic has 16 replies, 2 voices, and was last updated 12 years, 9 months ago by
nilocp.
July 12, 2013 at 12:33 pm #76183
nilocp
ParticipantWe have a Whirlpool AWO/D 049 washing machine. It is integrated but apart from that it is just a washing machine to me :rolls: :rolls:
It stopped mid cycle a while ago, and because it is at our house abroad, I thought, after close inspection, that it must be a board failure. It was totally dead!
So I ordered and eventually got a new control board from 4ourhouse at a cost of £175!!!
So I have now fitted this. Guess what, doesnt work ❗ ❗
But we do have lights.
As soon as you turn the dial to any position it sounds like there is a pump working, but nothing happens. No water gets in. And that is without pressing start!
The service light is on and also the lights for rinse and spin / drain, and the start light is flashing.
We will have invested about £800 in this now, with purchase, shipping and now the new module.
Whirlpool as might be expected are even worse than I would have expected.
Is there some sort of reset you have to do, or are the flashing lights an error code?
Come on guys I cannot afford to scrap the damn thing. It will only have done a dozen washes 😥 😥 😥
July 12, 2013 at 12:54 pm #397491Martin
ParticipantRe: Whirlpool AWO/D 049 issues!!
Sounds very much like that control PCB is NOT pre-programmed…….oh dear! 🙁
Paddle, creek, up and all that……
What is the full part number of the PCB you bought anyway?
July 12, 2013 at 1:32 pm #397492nilocp
WPL481221470499 described as Module – programmed. They obviously had all the numbers from the Machine, and I had to wait ages for it. I think it came from Italy. I did query the part number as it was different to the old one. They assured me it was the correct one for the machine!
July 12, 2013 at 6:12 pm #397493Martin
Yes it appears to be the correct part though it your diagnosis as to the fault is likely to be questionable? So, time to roll up the sleeves and get down and dirty on this armed with a full set of tools and a proper test meter. Check out : the motor, heater, pump, wiring, inlet valves, door interlock, pressure system………let us know how you get on? Have fun! 😀
July 12, 2013 at 8:10 pm #397494nilocp
Whoaaa! Well outside my capabilities without some sort of manual!!
July 12, 2013 at 8:48 pm #397495Martin
nilocp wrote:Whoaaa! Well outside my capabilities without some sort of manual!!
Aaaaah, then time perhaps for a rethink……hmmmm?…..it’s locate “abroad” you say? They don’t do manuals these days it’s all on computer accessible only to local dealerships. And that may be your only option, to call out a local agent, I reckon.
July 12, 2013 at 10:22 pm #397496nilocp
We are in Barbados, and the local Whirlpool guys only do American machines I am afraid! Most of those are steam driven, a few electric now!!!!!
July 13, 2013 at 7:25 am #397497Martin
nilocp wrote:We are in Barbados, and the local Whirlpool guys only do American machines I am afraid! Most of those are steam driven, a few electric now!!!!!
Offer a free weeks accommodation for a UK Whirlpool engineer and his family to come over and stay and fix it for you. 💡 (must bring toolbox)
July 13, 2013 at 10:54 pm #397498nilocp
Martin, do you know anyone who might be prepared to do that?
He said…………………..!
July 14, 2013 at 6:59 am #397499Martin
nilocp wrote:Martin, do you know anyone who might be prepared to do that?
He said…………………..!
Throw in free return flights with Virgin Atlantic and there may be a few guys up for it? 😉
July 15, 2013 at 1:18 pm #397500nilocp
Right enough of this silliness! 😆 😆 😆
Anyone else got any suggestions?
Is there some sort of reset procedure I can do.
Or does anyone know the error codes?
Ta
Colin
July 15, 2013 at 2:19 pm #397501Martin
nilocp wrote:Anyone else got any suggestions?
Read again my 2nd reply to you and carry out those tests.
nilocp wrote:Is there some sort of reset procedure I can do.
Not that I’m aware of though the Whirlpool guys could check the module with their test software. (they all carry laptops to do that these days)
nilocp wrote:Or does anyone know the error codes?
Error codes won’t show as long as the unit you have is at fault. That is why I stress you need first to check the rest of the machine out to establish whether or not a faulty component is causing a problem with the board. If and when it does eventually burst into life and display an error code do get back to us an we can probably tell you what that means.
One thing does seriously puzzle me though……….. If the machine is actually in Barbados as you claim, over there they have 110 volts not 240 volts, so the darn thing wouldn’t work anyway surely as you brought it over from Blighty???
I reckon a trip into Bridgetown to check out the latest Maytags down there be da way forward…..less hassle, stay cool man! 😉 😀
July 15, 2013 at 3:54 pm #397502nilocp
Martin most appliances here, even US, are 220 / 240. All new houses have 110 and 220. 50 cycles just to confuse even more. That’s fun! But 110 barely makes you jump! :rotl: :rotl:
July 15, 2013 at 4:12 pm #397503Martin
nilocp wrote:But 110 barely makes you jump!:
Hmmmm?…….so your Bajun bolt hole is on 240 then?
July 15, 2013 at 9:21 pm #397504nilocp
Lights all 110. Power 110 or 220, depending which room you are in!! Sockets have different pin orientation luckily!
