Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool diplomat ADP8322 no error codes or beep
- This topic has 15 replies, 3 voices, and was last updated 11 years, 2 months ago by
Mark9.
January 10, 2015 at 9:31 pm #83699
Mark9
ParticipantHi my whirlpool diplomat dishwasher was running great until the other day I came in from work and I could hear it beeping so I canceld the beeping and thought I’ll look at it later
so I set it away on a rinse and it starts doing its thing but about 1 minute in there is is a noise like when it drops the tablet like a bang then the machine stops no flashing lights no beeps so I can’t get a error code to point me in right direction
Iv have it on its side today and had a look but nothing looks damagedAny help would be very helpful thanks
January 10, 2015 at 11:49 pm #423479electrofix
ModeratorRe: Whirlpool diplomat ADP8322 no error codes or beep
they have a habit of breaking wires at the bottom of the door. remove door cover and check wires as they bend to go underneath, be careful if there are breaks make sure you know which wire joints to what as a lot of them are black
January 11, 2015 at 12:07 am #423480Mark9
ParticipantRe: Whirlpool diplomat ADP8322 no error codes or beep
Hi I had the door covers off today all wires looked intact no insulation damaged to the wires but the plastic trunking was damaged I will replace this once it back up and running
January 11, 2015 at 12:21 am #423481electrofix
bit lost for ideas now. soap dispensor is not used on rinse so cant think what the noise can be
to go through it
set and start prog
drain pump runs y?n
drain pump stops and machine fills y/n
main wash motor starts y/nDave
January 11, 2015 at 12:40 am #423482Mark9
When it stops I open the door any the bottom in full of water if I press start button and shut door it pumps water back out open the door again no water were filter is
So not sure what pumps are or are not working strange how there’s no errors showingJanuary 11, 2015 at 1:09 am #423483electrofix
first off the drain punp should start bit of a whiring sound
than this stops and machine fills
then the main motor kicks in you will hear a louder wooshing sound
these main motors fail and when thay do they can go in one of 2 ways
way 1 you get a throbbing sound
way 2 complete silenceyou may have a main motor failure current part no 481010625629
do a google image search of number. to be certain you have to check for power on the motor but no start
DaveJanuary 11, 2015 at 12:10 pm #423484Mark9
Iv just taken the circulation pump out and stripped it down on th impeller part there is like a metal looking shaft part that looks like it’s cracked on both sides or I they meant to look like that I’ll leave it out for now
January 11, 2015 at 2:34 pm #423485Mark9
Not sure if this is ment to look like this
January 11, 2015 at 6:58 pm #423486Mark9
Any suggestions ?
January 11, 2015 at 9:40 pm #423487electrofix
thats you problem its shot
thats a magnet
January 11, 2015 at 9:50 pm #423488Mark9
Yeah I’m glad if found something looks like I need to order a new motor thanks for you help
January 11, 2015 at 9:55 pm #423489clivejameson
Another Askoll pump, not a very successful experiment by Whirlpool! The part number Dave gave is a conversion to the older (much more reliable) pump…looks very different but will sort the problem…
January 11, 2015 at 10:04 pm #423490electrofix
nope they stopped using the old good pump and found another cheaper one. works same as the askol
January 11, 2015 at 10:10 pm #423491clivejameson
Yes, i meant the old ‘type’ pump…cap run motor through a seal…
Hope it doesn’t work the same as the Askoll 😆
January 11, 2015 at 10:21 pm #423492electrofix
no luckily just a cheaper plastic version of old metal motor
added picture thanks to Qualtex
