Zanussi ZJD1285
Viewing 8 posts - 16 through 23 (of 23 total)
  • #140372
    Re: Zanussi ZJD1285
    Still waiting for the bearing kit for this.
    Anyone know of an alternative to Qualtex’s BKT 80. Do Zanussi do a complete kit or do I need to order separate bearings and seal.
    Customer giving me some earache now. 😥
    #140373
    Goatboy
    Re: Zanussi ZJD1285
    You can order seperate bearings from electrue for about £3 each, it’s just getting the right seal that’s the tricky bit. If you have their home laundry catalogue, check out page 8.
    Edit – electrue part number for these bearings is the bearing size. ie you need a 6207zz and a 6206zz
    ps. catches win matches 🙁
    #140374
    Dave_Conway
    Re: Zanussi ZJD1285
    No bearing kit available from Zanussi but the bearkdown is:
    Bearings – 1 x 6206 and 1 x 6207
    Shaft seal part number 1240244002 in stock at Connect (about a fiver).
    #140375
    Washman
    Re: Zanussi ZJD1285
    Hi all
    What about bearing kit 1000+ rpm DST 344703012 £8.84 trade or BRG942260 £5.41 trade both in stock on connections
    Mike
    #140376
    Dave_Conway
    Re: Zanussi ZJD1285
    The seal is different Mike, although I’m not sure what the difference is, it’s a different part number that the usual 1000+ bearing kit.
    #140377
    Washman
    Re: Zanussi ZJD1285
    Hi Dave
    Have just been looking at connections and cross checking that seal against other models that these 2 kits fit and it looks OK
    Mike
    #140378
    Dave_Conway
    Re: Zanussi ZJD1285
    Good news then :tup:
    #140379
    Re: Zanussi ZJD1285
    Thanks for the info, actually the WMA bearings look to be the exact same size, pity the seal is different.
    Just checked and the WMA bearings are the same size. 🙂
