Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWD12270w only partially drains
- This topic has 16 replies, 2 voices, and was last updated 10 years, 4 months ago by
bigelf.
November 27, 2015 at 12:44 pm #86838
bigelf
ParticipantZanussi ZWD12270w
get e20 error in cycle
seems to be a drain problem
I thought it was the motor but it seems not (?)
It drains quite strongly for about 30 seconds but then nothing even though the drain still seems to be pumping.
I have tried draining a few times and its the same each time. Strong water pumping for 30 seconds if the drum has some water then nothing though it’s still pumping.
When I check the emergency filter there is still quite a lot of water in there.update :
It seems to drain water in any mode but leaves about 1-2 litres which is in the filter. If I drain a full wash it empties 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the water. So for some reason it keeps leaving ~1 litre in any cycle. A dryer issue ?Any thoughts appreciated.
November 27, 2015 at 12:56 pm #433163bigelf
ParticipantRe: Zanussi ZWD12270w only partially drains
ignore this.
it seems to drain any amount (1/2 / full) but leaves about 1 litre of water.It seems to start pumping out strongly (I can see the water in the sink) and after about 20 seconds a 2nd motor starts and this seems to stop the draining (but not the motor sounds)
November 27, 2015 at 2:27 pm #433164Martin
It’s a gravity fed pump and not a suction pump therefore whatever pipe work lies beyond the pump and its final outlet will equal the quantity of water remaining.
November 27, 2015 at 2:45 pm #433165bigelf
thanks
so you mean it is normal in this machine to have maybe 1 litre left ?
The E20 error is a new issue.
November 27, 2015 at 4:00 pm #433166bigelf
tried 2 full washes and a dryer cycle
the 2 washes went ok
But the dryer stopped about 10 minutes in with E20
It seems to be a dryer problem ?November 27, 2015 at 4:02 pm #433167Martin
E20 tumble dryer error refers NOT to a drain fault but indicates a fluff blockage in the condenser unit.
November 27, 2015 at 4:13 pm #433168bigelf
Thanks. Would I be able to fix this myself ?
Where is the condenser unit ?
I have no idea
I see another siphon come out the drum that is not the wash drain siphonNovember 27, 2015 at 4:25 pm #433169Martin
Access to the condenser requires a good degree of major surgery. Lots to remove inside, not for the faint hearted. It might be far better to call in a local repair person if the challenge is too great.
(Sorry but we cannot talk/type you through the various stages in order to assist otherwise) 🙁
November 27, 2015 at 4:33 pm #433170bigelf
OK thanks Martin
I tend to do 2 things that may have caused it.
A few times I have used those ‘woolly tumbler balls’ supposed to help with lofting
I also tend to put quite wet clothes in the dryer.
Anyhow, at least I still have a washing machine.November 27, 2015 at 4:57 pm #433171bigelf
I was reading another site that says to find the fault
select a program (not first one) and press and hold start and button to the leftI tried this and got ‘ ed4 ‘
November 27, 2015 at 5:31 pm #433172Martin
bigelf wrote:I tried this and got ‘ ed4 ‘
Oh don’t over complicate the basic problem with possible erroneous fault codes from button pressing.
But ED4 relates to ‘Dryer Relays Faulty’…..nope, mean neither. Disregard 😉
November 28, 2015 at 3:19 am #433173bigelf
self-fixing : do you think this is beyond me ? e.g. I guess it’s not a case of trying to stick a wire through a pipe ?
Do you think I would need a new part ?
I see Currys would be £119 to repair including part (if I read right)
November 28, 2015 at 7:49 am #433174bigelf
is this where my fault likely is ?
I think I can see this in the far right corner. With a fanbelt on itNovember 28, 2015 at 7:51 am #433175bigelf
general question
Do new washer dryers still have a potential ‘lint-dryer’ blockage problem ?
Or is it a thing of the past for older machines ?I see indesit washer dryers seem to have a ‘fluff filter’, whereas Hoover do not seem to ?
November 28, 2015 at 8:14 am #433176Martin
YouTube is a brilliant media tool but boy does it ever give wrong or bad advice. LG and Zanussi are two separate beasts. Access to each far different.
Lint problems on washer/dryers a major issue. 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} don’t have lint filters including Zanussi.
Currys repair service an expensive joke. Local repair guy is who you need call. Don’t start poking wire about meanwhile by the way.
