Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWD81683 – No heat on dry and counts down really quickly
- This topic has 15 replies, 3 voices, and was last updated 6 years, 3 months ago by
asp11.
December 9, 2019 at 6:26 pm #96854
asp11
ParticipantThis machine works fine on wash but fails on dry…
It doesn’t heat but the fan motor runs fine, the time starts normally but then goes down quickly…… the same fault occured a year or so ago and the thermister on the ducting was changed and the wiring loosened BUT it’s not been used much so I dont think its that again??!! ANY IDEAS PLEASE?
December 9, 2019 at 6:38 pm #465057electrofix
Moderatorthe top thermistor is a common problem on this model. if the job was done correctly then a new wiring harness should have been fitted. If this was not done then it is possible the wire has broken again
December 9, 2019 at 6:51 pm #465058asp11
ParticipantThe wires have plenty of flex in them and a zanussi engineer did replace the wiring back when it was changed before (approx 18m – 2yr ago) … could it really be the same part again or something else causing the error?
December 9, 2019 at 7:17 pm #465059Specialist01269
ParticipantWhat have you actually checked or tested so far ?.
December 9, 2019 at 7:37 pm #465060asp11
ParticipantI’m actually going on wednesday, just doing some research beforehand
December 9, 2019 at 8:11 pm #465061Specialist01269
ParticipantIf you want meaningful / useful answers, it would be a good idea to go and do some checking & testing first. It may be something that you can find quickly, but if not we should at least have something to go on.
December 9, 2019 at 8:12 pm #465062electrofix
Moderatorhave you got access to tech ?
December 9, 2019 at 8:16 pm #465063Specialist01269
Participantasp11 wrote:I’m actually going on wednesday, just doing some research beforehand
If you haven’t been to the job yet, how could you tell Dave that there’s plenty of flex in the wires ?.
December 10, 2019 at 7:34 pm #465064asp11
The cx has taken the top off and checked because he saw the last engineer to that repair before, so he told me – I’m just doing some research before my call out, you guys on here have always been great with helping
December 10, 2019 at 7:35 pm #465065asp11
Participantelectrofix wrote:have you got access to tech ?
Sadly not Dave — I normally have great success on here with you guys so I’m just doing a little research before seeing the machine tomorrow
December 10, 2019 at 8:14 pm #465066electrofix
only ask because I have
let me have an email addDave
December 12, 2019 at 5:13 pm #465067asp11
Great Dave……. it’s asp11@hotmail.co.uk
December 12, 2019 at 6:20 pm #465068asp11
ParticipantAfter checking this machine in person I found the Duct thermister had plenty of slack in the wires but the last engineer used a crimp connector to join them and not a complete wire from pcb-thermistor…… but the wires are tight.
What I did find was that when the dryer kicked in, there was mains to the element for only a second then no more – I waited 10mins but no other power came to the dryer element AND I found the time stayed normal for me, the cx says it normally reduces fairly quickly
Am I looking at a main pcb error, as I thought I heard a relay noise when there was power to the dryer element for a second but nothing afterwards????
December 12, 2019 at 6:22 pm #465069asp11
ParticipantZwd81683nw 62800001 914604535-00
December 12, 2019 at 9:36 pm #465070electrofix
Moderatorsorted manuals etc
