Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF 1021
- This topic has 16 replies, 4 voices, and was last updated 12 years, 7 months ago by
Muv.
September 9, 2013 at 12:23 pm #77044
Muv
ParticipantGot to change a door boot on one of these,just need to know if these are the type with a welded casing, or does the front panel come away?
MartinSeptember 9, 2013 at 3:46 pm #400528Seamy
ParticipantRe: Zanussi ZWF 1021
On a ZWF1021.
Its a 5 minute procedure through the door, never took the front off one.
But in answer to your question, yes it comes off.If its however an older type ZWF1021W, its the older type of zanny, that outer casing splits at the sides.
September 9, 2013 at 3:51 pm #400529Andy jones
Yep door it though the front, should be able to fit it before they boil the kettle for your coffee
Sent from my iPad using Tapatalk HDSeptember 9, 2013 at 5:14 pm #400530Muv
Yes its the modern version,so i can do it without removing the front weight i assume?
September 9, 2013 at 5:18 pm #400531Seamy
Yep, easy peezy, lemon squeezy on the pinkies
September 9, 2013 at 5:23 pm #400532Muv
Thanks guys, have yet to try that method, should be fun!
MartinSeptember 9, 2013 at 5:36 pm #400533Andy jones
Same as the Bosch mate. One of the easiest seals to fit. Hope that’s not the kiss of death
Sent from my iPad using Tapatalk HDSeptember 12, 2013 at 9:38 am #400534Muv
Well door boot was pretty easy, few cuts on pinkies, but nothing life threatining!
Customer also complained of door taking ages to unlock,ranging from 20 mins, to the following morning!.. Pressure vessel clear as a bell,presssure switch seems fine.
I put it down to faulty interlock, and door catch, so have now changed these items.
I now have exactly the same problem, am i missing the obvious here?
MartinSeptember 12, 2013 at 9:39 am #400535Muv
Forgot to add, that even with interlock manually latched, it still takes forever.
MartinSeptember 12, 2013 at 9:51 am #400536Seamy
New interlock required, some of them take an age to cool off
September 12, 2013 at 1:41 pm #400537Muv
Did replace with new,you think these may be at fault?
September 12, 2013 at 3:24 pm #400538Martin
Muv wrote: am i missing the obvious here?
Fault only occurred after fitting door boot……….?
Hmmmm…?…….Tight fit closing the door is it?
September 12, 2013 at 5:09 pm #400539Muv
Was thinking it may be that, martin, but even with door wide open and interlock manually latched, using my patented latching tool (terminal screwdriver).. Its still bot unlatching for around 15-20 minutes…
M
MartinSeptember 12, 2013 at 5:32 pm #400540Martin
Hmmm? Not had a prob with interlocks, especially new ones, like this. So my only thought is that either the heater has an earth leak or the pressure switch contacts are sticking.
September 12, 2013 at 5:51 pm #400541Andy jones
New one on me that, got to be sticking contacts on ps I would imagine
Sent from my iPad using Tapatalk HD -
