Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi zwg1140m
- This topic has 29 replies, 2 voices, and was last updated 5 years, 7 months ago by
Lochgilphead.
September 6, 2020 at 10:39 am #471719
Moderatoras i said above you need to host them offsite on google pics or similar
then post a public linkthere are size constraints on here to save server space
September 6, 2020 at 10:55 am #471720Lochgilphead
ParticipantSeptember 6, 2020 at 10:58 am #471721Lochgilphead
ParticipantSeptember 6, 2020 at 11:03 am #471722electrofix
Moderatortny276pn next to the small yellow transformer
there are lots on Ebay
https://www.ebay.co.uk/itm/TNY276PN-…8AAOxy2d9SX9lp
also the is a diode next to it. if you have a multi meter we could do with checking that as wellDave
September 6, 2020 at 11:45 am #471723Lochgilphead
ParticipantThe diode, just below tyn276 and numbered D1, gives a fluctuating reading up to 19 then settles back to 1, thats on a resistance setting of 20k. I can’t get a reading from tyn276, but I’m not quite sure which two contacts to use.
Where can I buy such a diode?Many thanks for all your help, Dave, it is very much appreciated indeed.
September 6, 2020 at 12:12 pm #471724electrofix
Moderatoryou wont get any reading on the tny you just have to swop it to find out
has the meter got a diode testing setting ? most have
put your leads on the diode then reverse them. if you get the same both ways then its suspect
September 6, 2020 at 2:28 pm #471725Lochgilphead
ParticipantI get a reading of 384 one way and initially a multitude of readings the other steadying to 1.
September 6, 2020 at 2:58 pm #471726electrofix
Moderatorits probably ok then. if it goes short both reading would be the same.
also now thinking about it when they fail the machine does not work at all
so its probalby the chipDave
September 6, 2020 at 3:13 pm #471727Lochgilphead
ParticipantHopefully I will get the chip towards the end of the coming week. I’ll let you know how the repair goes.
In the mean time, once again, thank you for all your help.Dave
September 12, 2020 at 11:14 am #471728Lochgilphead
ParticipantDave,
I have soldered in the new piece, I don’t think too good a job unfortunately, now when the power is back on all the programs are mixed up. I think perhaps a new machine is now required.
September 12, 2020 at 11:52 am #471729electrofix
Moderatorare you sure u got the knob and shaft in correctly as what you have repaired cant jumble the programmes
turn the knob till it turns off and see where its pointing
September 12, 2020 at 2:11 pm #471730Lochgilphead
ParticipantYes, if I turn the knob to ‘wool’ it turns the machine off so it is 25{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} further along. I’ll take the pcb off again and try to see what I have done wrong!
September 13, 2020 at 11:09 am #471731Lochgilphead
ParticipantDave,
That’s it finished and working! Many, many thanks for all your help and knowledge, I simply could not have done that on my own. And thanks to uk whitegoods.
With best wishes
September 13, 2020 at 11:17 am #471732electrofix
Moderatorwell done
its a nice feeling when you acomplish the impossible isn’t it
September 13, 2020 at 11:41 am #471733Lochgilphead
ParticipantIt is indeed because on my own it would have been impossible.
