1/4″ Olive
Viewing 12 posts - 1 through 12 (of 12 total)
  • #63567
    Just wondered if anyone has an old imperial size olive for connecting my 35 year old Flavel B700 caravan cooker? I intend to use it at my place in Hungary for summer use. I’m putting in an AGA type cooker for the winter but won’t want that going in warm weather.
    #354149
    Re: 1/4" Olive
    E-mail me your addy
    #354150
    Re: 1/4" Olive
    Thanks Bryan. 🙂
    #354151
    Re: 1/4" Olive
    Can anyone else help with this?
    #354152
    don
    Re: 1/4" Olive
    I just found one here from a Google search.
    Cheaper than chips as well 😆
    Don
    #354153
    Re: 1/4" Olive
    Thanks don. It’s about £6 including post and VAT but I might end up ordering one off them.
    #354154
    Re: 1/4" Olive
    Ive sent it out.
    #354155
    Re: 1/4" Olive
    Thanks for the olive, Bryan. Unfortunately it’s too small. I can’t measure the I/D directly but it just fits nicely over a screwdriver bit that measures 0.240″. I would think it is meant to be 6mm (0,236″).
    #354156
    Re: 1/4" Olive
    It’s a 1/4″ from an american installation kit and fitted onto 1/4″ refrigeration pipe.
    Gas pipework isn’t normally 1/4″ but either mm
    #354157
    Re: 1/4" Olive
    Flavel work in metric so my guess is the olive would need to be either 6mm or 8mm?
    Best to order both then you’re covered. 😉
    #354158
    Re: 1/4" Olive
    No, I’ve measured the pipe with a micrometer and it is definitely 0.250″. I might try poking the 1/4″ pipe into a bit of 8mm pipe and soldering round the join and then attach that to the rubber tube that goes to the bottle regulator.
    #354159
    Re: 1/4" Olive
    I now have the correct olive, ordered from this site:
    http://www.leisureshopdirect.com/carava … iping.aspx
