120 Volt pump
Viewing 7 posts - 1 through 7 (of 7 total)
  • #7433
    Ralph
    Hi im looking for any info regarding a drain pump
    it is a magnetic standard plaset/askoll fitting
    it came off a frigidaire washer which came off a ship
    that is currently in port
    the pump is 120 volts and 60htz
    any info gladly received
    #123230
    Re: 120 Volt pump
    Simple modification can be done on this to use a standard 240v pump.
    Go to maplins or rs components and get a 110v relay this wired in will supply the neccasery 240v to new pump.
    job done
    as long as it isnt under warranty and labeled you shouldnt have a problem.
    bryan
    #123231
    chezza
    Re: 120 Volt pump
    you could try http://www.jla.com , at their spares dept.- they are commercial laundry company, and i know a couple of years ago, they had large stocks of 110 volt pumps as used on the maytag neptune washer they were selling .
    they were the usual permag type pump – you may need to change the cap.
    eddie
    #123232
    Ralph
    Re: 120 Volt pump
    Thank you gentlemen
    that gives me a couple of options
    Thanks again
    Ralph
    #123233
    TECHBOIS
    Re: 120 Volt pump
    We have just received a few by mistake, if you give Andy a call on 01702 465534, we will be able to help.
    Richard
    http://www.masterpart.com
    #123234
    Re: 120 Volt pump
    Glad you noticed, Richard, and did not ship them out to the trade as 240v items as an un named supplier did a few years back with fridge bulbs, they were all 120v versions in 240v boxs, boy were they bright….for a short while 💡
    #123235
    shane
    Re: 120 Volt pump
    Ralph wrote:Hi im looking for any info regarding a drain pump
    We had trouble with this type of pump a few years ago. It was a standard British Zanussi installed in a van on a Drilling Rig powerd by a big diesesl generator running at 240v at 60Hz. The pump was unreliable, frequently it would not start. I changed the pump; ten times no better ! I consulted Zanussi Technical and was assured a 50HZ pump would not be reliable at 60Hz. They tried to get a 60Hz unit but it never appeared.
    The Site operators bored a hole in the floor of the van and stuck the drain
    hose through the hole to drain the machine, then lifted it up to do the next stage of the programme. It must have been a very tedious task doing the laundry.
    The drilling site was on hundreds of acres of sand dunes so the waste water just soaked away into the sand.
    Shane.
