Thermistor is ok, I must admit I didn’t check the PS as it had filled to the correct level several times during first testing, so I assumed it would be ok. :clown:
have had these heating for just a very short time as limescale under the heater keeps water off the area above the ntc so it reads that it is up to temp in an instant and therefore cuts the power to the element. If you meters not hooked up or just not looking at it you may miss it. Best test is to pull the ntc from its slot above the motor and test the machine on a wash again with it dangling, don’t forget to re fit it though.
