Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › 25 yr old Tricity Ckr integr. 4175 needs hinge repairs.
- This topic has 3 replies, 3 voices, and was last updated 15 years, 6 months ago by
leavemetogetonwithit.
September 29, 2010 at 12:30 pm #57582
ParticipantAlmost certainly obsolete. I haven’t been to check it out yet but woman said there was a bang as door fell open and it wouldn’t shut again. Oven working otherwise. I don’t want to send anyone off searching their garage upside down for a part which may not even be there but just wondered if anyone had had any experience repairing broken hinges perhaps using parts from other models? I imagine it will be the pins in the hinge finally given way?
Or perhaps someone has found a work around for this sort of problem?
I think these cookers are a bit wider than the modern ones aren’t they? So it would mean work to modify woodwork etc. to replace it (built-in). Also I fixed elements, cut-out etc about a year ago which involved a £100 bill IIRC, so don’t really want to tell them to scrap it now. On top of all that customers in the 80/90 age group and might not need cooker much longer 🙁 . There again might not need money much longer either :).
Any ideas appreciated.
Mike.September 29, 2010 at 1:06 pm #331656electrofix
ModeratorRe: 25 yr old Tricity Ckr integr. 4175 needs hinge repairs.
god i am having to think back now
you say door opens and closes but does not lock so cant be hingeson some old tricity’s you turn the knob on the outside of the door to open and close them part inside door snaps can go with a bang as it has a small spring attached
part still avail in stock at qualtex
part number CS27
hope this helps
September 29, 2010 at 2:22 pm #331657don
As far as the physical size goes Mike I think the width will be the same but they were taller IIRC by about 3 inches, so at worst all that would be required would be a small infill panel.
Don
September 29, 2010 at 4:58 pm #331658leavemetogetonwithit
ParticipantRe: 25 yr old Tricity Ckr integr. 4175 needs hinge repairs.
Thanks for info, guys. I guess I’d better get out of my armchair and go and have a look tomorrow. Just back from holiday and very reluctant to start working again.
Mike. -
