40 year old tricity double oven.
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts 40 year old tricity double oven.
  • #99708
    deltra
    hi all, been to this oven ,no modelnumber. fault is no heat, looks like a temp limiter has burned out,(tried temporary stat and all worked) question is ,whats the old stat rated? numberrs on stat are,L330, 495-082, 8339, tried looking on net, any help much appreciated.
    #477507
    deltra
    think it may be tricity 2166
    #477508
    electrofix
    well going by the age of this and taking a guess i would say L330 is the temp but in degrees F. Thats 166 degrees C which sounds about right
    not sure if i have any manuals for these tucked away
    if i think on will look tomorrow
    dave
    #477509
    deltra
    thanks dave,you might have made a couple of pensioners very happy.the stat/thermal cutout/fuse thing is in line with heater and bolted to cabinet.
    #477510
    deltra
    did you find anything dave?
    #477511
    electrofix
    oops forgot having one of those weeks
    will set an alarm for tuesday when i am back in to remind my old brain
    deltra
    😀 i thought it was only me that had those weeks:o
    #477513
    electrofix
    only got manuals for models 2106 and 2735 both don’t seem to have a stat
    looking on the net the only stats I can see labelled L330 seem to be American so with that in mind I am assuming its degrees F
    to the closest I can find is
    https://shop.ukwhitegoods.co.uk/300180158-thermal-cut-out-switch
    rated 175 degrees which is just over. Its not as critical in an oven to be bit higher as they are designed not to go on fire because of the elements
    deltra
    thanks dave.
