I am trying to source a fridge (no freezer) for a space that is only 53 cm wide. I cannot find one online anywhere. Can anybody recommend one? Height should be over 140cm. Depth not an issue.
Thanks
Sadly your between a rock and a hard place, to get to a height over 140cm it would need to be 55cm wide which is too wide. If you then drop down to the next size down which is 50cm there are no tall ones produced.
The only solutions would be to increase the width of the space or install two 50cm wide fridges one over the other with a shelf in between.
