60Hz
Viewing 6 posts - 1 through 6 (of 6 total)
  • #28772
    electrofix
    got a hoover auto on board a ferry machine is marked with a label on rear 240v 60hz
    this is a new machine but main motor will not work with load in it but works ok with non
    checked motor and it is labelled 240v 50 hz
    question is this motor ok on 60hz and will it lose power or is the wrong motor fitted and is there a 60hz replacement
    have got mod but not to hand can be supplied if needed
    Re: 60Hz
    What is the supply voltage and frequency rating on the ferry?
    #219984
    funkyboogy
    Re: 60Hz
    I HAD THIS BEFORE,
    i think ive got this the right way…
    mainland is 50 hz
    boats produce 60hz , so motor/pump dont run prop..
    no cure for this, unless you fit a motor that can run@ 60 hz
    ally
    #219985
    electrofix
    Re: 60Hz
    this machine supplied to work on 230 60hz but motor clearly labelled 50 hz pump has been changed and works ok
    need to tech advice from manufacturer but its a hoover not sure what they will tell me
    spanner51
    Re: 60Hz
    I have come across a few domestic machines on boats which were converted for 60hz use. The conversions were done by Southern Contracts Ltd of Bournemouth. You could give them a call as they are usually helpfull. 01202 422100
    #219987
    electrofix
    Re: 60Hz
    think it was them who supplied machine but thank for number
    have scrapped machine for 60hz work will try it on 50hz when on dry land and report back
    thanks for replies
