701
Viewing 8 posts - 1 through 8 (of 8 total)
  • #9967
    alexa
    Hi Alexa,
    I have a Faulty Fisher & Paykel 701 that looks to be in some form of fault mode. I noticed you have the diagnostics for the 701. Could I please impose for a copy?
    Thanks,
    Joe
    jlmizzi@ozemail.com.au
    Have sent you an email with the diagnostics
    Please post in the forum so that everyone can appreciate your post
    Cheers
    #137000
    Theos
    Yesterday it was having problems filling and having seen this before I thought it was the cold water valve so I replaced it. But now when I turn it on it goes straight into some form of error mode.
    When I turn it on it cycles through the keyboard then lights 4 LEDs.
    Middle LED in Wash Progress is ON
    Time Saver is LED is ON
    Warm wash LED is ON
    Med Spin Speed is ON
    Beeps when I press anything else
    Does this indicate anything?
    Thanks
    Joe
    #137001
    alexa
    Did you put a genuine valve in.
    Coil resistance should be 15 ohms
    #137002
    Theos
    Re: 701
    Yep new valve in an F&P Pack.
    Using the info you provided I now think the valve was OK and something else is wrong.
    I think it is in error mode and only the 5th LED is on in the wash readout.
    Does that mean anything?
    Thanks.
    Joe
    #137003
    alexa
    Re: 701
    Doesn’t sound good
    Post your email and I’ll send you the diagnostics
    #137004
    alexa
    Theos. I have resent the diagnostics to your previously posted email address
    #137005
    Theos
    Re: 701
    Yes I have these sheets thanks. I was hoping you also had the readout list from the LEDS, so I can decipher what is wrong with it.
    Any idea where I could get this from or a PDF of the complete manual?
    Many Thanks,
    Joe
    #137006
    alexa
    As the manual is copyright I cannot publish or resell the manual.
    If you post the specific readout then under copyright fair use policy I can send you that particular fault description
  • The topic ‘701’ is closed to new replies.
