904/2199/04 to /05 conversion
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries 904/2199/04 to /05 conversion
Viewing 4 posts - 1 through 4 (of 4 total)
  • #15546
    streetlighter
    Hi all
    Does anyone remember ( or have the tec sheet ) how to fit a hpt timer 904/2199/05 in the place of a 904/2199/04.
    Brought a 05 from connect to replace a 04 as stated in the list but it does’t say how to rewire for the rear plug. 🙁
    Ta
    Paul
    #164015
    Re: 904/2199/04 to /05 conversion
    I don’t have a tech sheet but do have the old manuals, if you can give me the model number and date code I should be able to identify which wires go to which connections on the timer for that white block. A long time since I changed one of these, if I remember there are some other wiring mods to accomodate a new, small two spade terminal plug just behind the red & green plugs and an alteration to the economy switch wiring. You never no someone may have saved a tech sheet, although it should be included with the timer with all the connections.
    #164016
    Twoten
    I think it’s leaflet number 820550 for timer kit 168887?
    If you pm you email address I will send it,
    Keith.
    #164017
    streetlighter
    Thanks very much keith
    Fitting it in the morning now I know how to 😆
    Ta
    Paul
