9605 top loader
Viewing 7 posts - 1 through 7 (of 7 total)
  • #78358
    clockworkone
    Need a bit of help with this one.First one ive had to look at.Washes ok but no spin.Is there any tech still out there on these.Also how is access got to workings.
    #405360
    Re: 9605 top loader
    Have you checked the clutch ? use a bit of emery cloth to roughen up or replace pads if they are still available.
    #405361
    Re: 9605 top loader
    clockworkone wrote:Need a bit of help with this one.First one ive had to look at.Washes ok but no spin.Is there any tech still out there on these.Also how is access got to workings.
    Fear not, we can talk you through his for darn sure. Firstly you need to check the drum spins freely by hand. To do that just release (by hand) the brake lever (that locks the drum shaft) and spin the drum (also by hand). It should rotate 2 or 3 revolutions with little resistance. If it doesn’t do that then you have problems. If it does then check out the clutch (as r600a refers) as it must be well worn and need replacing anyway. (Still available)
    HTH?
    #405362
    Andy jones
    Re: 9605 top loader
    Brings back fond memories. Love these machines, as said almost certainly clutch is worn, also have a look at the bellows seal at the top of the gearbox support tube for signs of leaking. Won’t cause a spin problem as such but may tell you what sort of condition the power unit is in
    Sent from my iPad using Tapatalk HD
    #405363
    clockworkone
    Re: 9605 top loader
    Many thanks for replies.Most certainly very useful advice.Any idea who still stocks these clutches.Paul
    #405364
    Re: 9605 top loader
    clockworkone wrote:Any idea who still stocks these clutches.Paul
    Most if not all wholesalers and Hotpoint or HERE even.
    #405365
    clockworkone
    Re: 9605 top loader
    Clutch it was..Obsolete at connect and m/part.Ukwhitegoods came up trumps.paul
