Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › A bit more -Rob and Dented, does this help?
- This topic has 4 replies, 2 voices, and was last updated 18 years, 11 months ago by
jomutimer.
April 17, 2007 at 4:34 pm #26677
jomutimer
ParticipantHi,
I am reposting this but with additional information, in case someone can nail this for me now.
I have a
Whirlpool ADG 994 AV
TYPE: NGLM
Service Code 8542 994 15420 33 9950 017636The problems are :-
1. The machine does not heat up
2. It stops just before the end the cycle.
This is the sequence of events:-
You select a programme and hit the start button and the machine fills. However the sequence I expect does not occur. I expect that it will do a rinse, drain, fill again, open the soap compartment, heat up, wash and dry. But that is not what happens. What happens is it fills, tben, for a couple of minutes it runs with the soap compartment closed. Then, without draining, the soap compartment opens and the cycle goes on for about 50 minutes – that is way longer than th whole cycle should take on 40 degrees. It then drains and stalls with the led flashing. If you hold the button a about five seconds it drains a bit more then stops ready for the next “cycle”.
On two forums it was suggested that this might be the ntc, so I changed the ntc. The faults are unchanged. How do I run this down?
Regards
Adrian
April 17, 2007 at 5:30 pm #211034DentedPorsche
ParticipantRe: A bit more -Rob and Dented, does this help?
Sounds like a heating fault to me. NTC, NTC wiring, heater, Heater wiring or PCB are the likely culprits.
NTC you’ve changed so unlikely that this is the fault.
You’ll need to meter out the heater and wiring to rule these out.
If everything tests ok then it’s possible it’s a faulty pcb.DP
April 17, 2007 at 6:27 pm #211035jomutimer
[You’ll need to meter out the heater and wiring to rule these out.
DP
What reading am I expecting from the heater element? What does it mean if it is higherthan expected ? What does it mean if it is lower?
April 18, 2007 at 10:00 am #211036jomutimer
ParticipantRe: Rob and Dented – I took readings and…
I have put two meters on the heater and I got the following readings.
From the simple continuity meter I got – no continuity.
From the proper multimeter set to 20k ohms I got an odd reading. It read 1 . That is 1, then a space, then a decimal point.
Do these readings tell us the heater is broken?
This thing has a flow through type of heater. When I look inside I see scale build up. It is only about 1mm thick, but could it have caused the heater to overheat at some point? Is there a reset switch somewhere? How do you operate it? I might as well try that first, if there is such a thing.
Hoping I will solve this. Stay with me guys!
Regards
Adrian
April 18, 2007 at 4:30 pm #211037DentedPorsche
You should have had continuity through the heater and toc.
Sounds like the toc on the heater has gone open circuit.
No reset switch.
Looks like a new heater required.DP
