This machine goes through the whole programme without heating.The heater meters ok but the board is not switching on the neutral circuit.The heater is live both sides.Checked pressure switch ok.Main suspect is board or sensor which is set in the sump with a 4 wire harness linking it to the board.Has anyone had a similar problem?
