A new place to go for tech support
Home Forums General Trade Forum A new place to go for tech support
  • #63477
    hotpointer
    I was on espares.co.uk just looking around when i came across there tech support
    Rory is espares forum admin is it just me or is he just trying to sell some parts
    I have a samsung washing machine B1415J. The water comes into the machine and is drained out continuosly without the water pump being on. Also gives an E9 error. Can anyone help Please.
    by Nash – 17 February 2011
    A
    The machine is syphoning.Check your outlet hose is not rammed down the pipe also check the stand pipe is 18 inches high. The fault code is telling you that the water is being drained from the machine
    by mayday1 – 25 February 2011
    A
    H Nash, it sounds as if the problem is with either the sump hose (the hose that drains the drum down to the pump) or the pump. Check both for damage, and replace as necessary.
    by Rory – 18 February 2011
    #353891
    Re: A new place to go for tech support
    Yup, I suspect you may be correct.
