A note about ‘Error Codes’
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum A note about ‘Error Codes’
Viewing 1 post (of 1 total)
  • #61635
    If your machine is giving you an ‘Error Code’ fault and your instruction booklet doesn’t give any explanation, then the answer may well have been given before in this very forum 💡
    Often manufacturers have their own unique error coding that covers all models within that range. (e.g.Hoover machines no matter what the model have exactly the same error code sequence “E1” E2 etc. Indesit do likewise and so do Hotpoint and so on) Therefore if you hit the ‘Search’ tab (at the top of this page) and type in just the error code, you may be surprised to find the subject has cropped up before and an explanation has already been given 🙂
    If not 🙁 then do please post the question by all means and we will see if we can find an answer for you….. 😀
    More info here about fault codes
  • The topic ‘A note about ‘Error Codes’’ is closed to new replies.
