Re: A1436 Ariston Dodgy Cold Fill Valve Assy
Thanks for your reply Jim but that part number you gave me comes up as a dispenser door. I believe the correct part number is C00115441.
As this new part seems the same as the old one so likely to happen again I have fitted the straight end of the fill hose to the end of the valve just inside the machine (machine is not under work top and can be kept well clear of wall)
Always believe in working to the book but in this case I will sleep easy feeling sure my mod is a better bet than Aristons 😉
