Re: Access to stoves base element
Job done, for others attempting this I would suggest wearing a dust mask and removing bottom storage drawer completely.Remove insulation from underneath cavity as neatly as you can, as this will help sticking it back together.Remove plate from below element, you can now see the offending item, now remove fan element cover from within cavity and you will notice a screw at the bottom centre line of oven cavity, this is what is holding the element in place,remove this and withdraw damaged element. Replace element, plate and insulation.
