I’ve just had the ‘board from my Diplomat ADP8132 repaired by QER in Cumbria. I posted it on Monday and it was back by the end of the week. They also gave some additional phone support, warning that the board had been damaged by an external source (possible the heater). Can I test the rest of the machine using a multimeter to find the fault?? It went phut near the end of its cycle leaving a small amount of water in the bottom and tripped the circuit protector. Please help. Thanks HM
I’ve just opened my returned PCB from QER and they’ve indicated that whatever caused the fault on the board came in from a particular cable. The cable goes to what looks like a sensor inside the door touching the inner surface (so presumably a thermistor?). I’ve measured the resistance of the sensor and it’s open circuit. Does that sound right?
