Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Adding brush control to a DC07
- This topic has 6 replies, 3 voices, and was last updated 20 years ago by
Pistol.
April 3, 2006 at 2:12 pm #16875
Pistol
ParticipantHi there,
Odd little problem here. We were given a Dyson DC07 vacuum cleaner as a wedding present, and presently it’s doing a fine job of cleaning our carpets. However, we’re getting a lot of redecoration done at the moment, including some fancy carpet in the hall and back bedroom which can’t be vacuumed by a cleaner with a brushbar! As well as laminate flooring in the back room which can’t be done either!
Since you can’t stop the brushbar on the DC07, I am shortly to be left with a vacuum cleaner that can only be used in two of the seven room of the house. That’s not much use! Should have got the brush control model, I know…
What I would like to know is whether the brush control assemblies are the same – i.e. could I buy the brush portion from another model and fit it to my DC07? I’ve got my eye on the front assembly from a DC04 which I’m assured by the seller will fit, but then they would say that eh!
April 3, 2006 at 3:54 pm #171951Goatboy
ParticipantRe: Adding brush control to a DC07 – possible?
Not a DC04 to a DC07.
But (in theory) you could get a DC07 head, with clutch, and fit it. Though it would be an awkward job.
April 3, 2006 at 9:41 pm #171952legsthediver
using second hand parts IF available.. If you brought it to MY shop.. it would cost approx £40-£50.. Which is reasonable for the amount of parts and labour required.. to back up lasy message, the dc04 bits (apart from clutch) will NOT fit.. Good luck..
April 4, 2006 at 9:29 am #171953Pistol
ParticipantWell I’ve found someone who says he can supply a complete head assembly, so I guess it depends on my ability to disassemble and reassemble that part of my Dyson without losing a myriad of tiny parts under the sofa 🙂
I think I’ll have a go at taking off all the user-servicable parts first, to give me an idea of the complexity of the task. Might as well take the opportunity to clean the filters!
Any advice on disassembling a Dyson head? (Beyond unplugging it first obviously!) If it looks too frightening to proceed further than removing the user-servicable parts, I guess I can always take it to a repairs shop to get it done.
April 4, 2006 at 11:08 am #171954Goatboy
They’re full of tiny little torx screw. But somebody at Dyson, realised that everyone has adaptors for torx screws. So now on the DC07, these screws are at the bottom of narrow deep shafts, so you can’t get your adaptor in there 🙁 and you’ll need to buy the correct screw-driver!
Saying that, there’s only one of these unacessible screws on the clutched head. Taking your old un-clutched one off should be easy 😀
Good luck, and let us know how you get on :tup:
April 4, 2006 at 12:12 pm #171955Pistol
ParticipantCheers!
I’ve found some extremely useful information on Dyson maintenance over at http://www.dyson-online.com – I’m pretty confident I can handle the disassembly and reassembly now (provided I don’t lose the screws 😉 )
I’ll report back when I’ve had a go – I can’t be the first to realise I need brush control after all, and £40 for the parts is pretty reasonable compared with the cost of replacing one Dyson with a new one!
I guess the only drawback would be that if I make an obvious hash of it my warranty will be void.
April 25, 2006 at 8:32 am #171956Pistol
Well, just to let you know, I did it successfully 🙂 I now have a Dyson I can use all over the house.
There’s a great exploded diagram of the two types of head assembly over at espares, hope they don’t mind if I link to it. The parts I ordered were:
Cleaner head assembly (1)
Brush housing assembly (6)
Clutch actuator outer (7)
Clutch Assembly (8 )
Clutch Cover (10)
Brushroll Assembly (12)
Soleplate Assembly (13)I managed to get a combination of new and second hand parts, total cost was under £40.
Using the information at Dyson-online’s technical advice pages it was pretty straightforward to work out how to disassemble the old head and reassemble the new one.
I’m still not convinced that a DC04 head wouldn’t fit on a DC07 – I’m certain that many of the parts I received were actually DC04 parts, and they all fitted together fine. I’m loath to recommend anyone to go out an buy a DC04 head in case I’m wrong, but given that I could have bought a complete DC04 head for £10 or so (!) I do wish I’d given it a go myself – if it didn’t fit I could have just ordered a couple of new DC07 parts rather than the whole lot, and the total would still have been less than I paid in the end.
Can’t complain though – in all, it was a lot cheaper than a new vacuum cleaner!
