Re: ADG 6552 7 flashes
Most likely cause is the flowmeter, try tightening the connections at the flow meter and at the module.
Before moving jobs I had a few of the newer machines giving error codes that had nothing whatsoever to do with the fault. For example one machine was flashing F7 and had a flooded base, another Flashing F4 turned out to be a duff NTC.
In the main the faults were mostly attributed to the NTC, flowmeter connections, pressure switch and corrupt software on the module (no heat was the usual one for the software).
Brian
