ADG 7550 Tripping out
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ADG 7550 Tripping out
  • #49079
    zigger1
    I have recently fitted a new circulating pump to my ADG 7550. When i use it now it will only complete a full cycle on the first setting which is just a basic rinse, on any other cycle it trips the power out after approx 10 mins of the cycle, any ideas why this could be please?
    #298701
    Re: ADG 7550 Tripping out
    Almost certainly the heater has an earth fault – switches on after about ten minutes.
    zigger1
    Thank you very much penguin 45, is there a simple solution do you know?
    #298703
    That’s what’s underneath – heater is in the shop, HERE.
    Stay safe, power off if you intend to do this yourself.
    zigger1
    So basically you’re saying the heater needs replacing aswell. Could it not just be a bit of water in the hetaer plug caused when i replaced the circ pump?
    #298705
    Possible – you need to get in there with a decent test meter and check.
