Now that I’ve finally managed to replace the motor on this machine I am having difficulty getting the decor door back on. It has been so long since I took it off I can’t remember which way it goes back on and don’t want to break any of the 4 plastic clips.
Am I right in saying there are no screws to be removed from machine door to aid fitting and it is just a case of inserting and sliding up or down?
from memory its screws 2 and 4 from the bottom but if you look at the square holes in the door only 4 screws line up
loosen these screws. offer the outer door up to the holes and lift to lock it. then carefully open the door whilst holding it in position. then lock the screws
That was exactly it. It had been so long since I had removed it I couldnt remember taking screws out and its even hard to see how they hold it in place but its back on and still working. Now I just need to get a slim hose clip as I dont have a crimper to fit the ones supplied with the motor…….
