Re: ADG 7560 – No power ???
Worse case scenario : The power cut may have caused a power surge that blew the main board?
If you are competent with electrics and have the tools and test meter then only by opening her up can you proceed further. It is almost impossible to predict what it may be otherwise. Other possibilities are : Rodent damaged, chewed the wires inside? (Mice love dishwashers) or a broken wire in the harness going up the front of the door?
If you need help then go to our ‘find an engineer’ section on the home page. Lots of experts down in wildest Devon that can sort it for you. 😀
