adg644 d/w
  • #78307
    clockworkone
    Fault reported was 7 flashes e7.Inlet hose kinked and both filter on inlet valve and filter on hose at tap gunked up.put mc on test and ran till heated up with no problem.reset m/c and left. Cust rings later and tells me it seems to be stuck on drying cycle.she also tells me it did this before as well(could have told me this earlier)Dishes seem washed ok she says.Matrix seemed to be fine.could this just be a dirty owi sensor causing this.No error codes being displayed.Sorry misplaced service no.
    #405169
    deltra
    Re: adg644 d/w
    Whirlpool 7flashes=flow meter!!
    #405170
    clockworkone
    Re: adg644 d/w
    Thank you Deltra. Should have said that I cleared e7. Cleaned reed sw connections. No fault codes showing now.cust says it seems stuck on drying mode.I suspect it may still be stuck on wash program.Did not look when there but suspect if glass owi fitted that it may be dirty.
    #405171
    deltra
    Re: adg644 d/w
    Also burnt and broken wires in door are a common prob
