Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ADG7470/1 Flashes 8 times
- This topic has 8 replies, 4 voices, and was last updated 8 years, 9 months ago by
rolf.
July 12, 2017 at 12:28 pm #91660
rolf
ParticipantHello.
I’ve got a Whirlpool dishwasher ADG7470/1—-854274715001.
Drain pump runs and pauses a number of times then after 5 mins flashes 8 times.I popped the front cover off and was expecting to find a pressure sensor with the mesh but not on this newer type one.
Would anyone be able to elaborate what 8 flashes is referring to.
Thankyou.July 12, 2017 at 4:58 pm #448890electrofix
ModeratorRe: ADG7470/1 Flashes 8 times
check your pm’s
July 12, 2017 at 7:15 pm #448891rolf
ParticipantRe: ADG7470/1 Flashes 8 times
Thank you very much Dave, it suggests it could be the OWI or pump problem but it drains fine so leaves me with a OWI problem.
As far as I could see there isn’t one on the machine but the exploded diagram shows either a OWI or pressure switch in the same place but no part numbers. 😕
Would you know how this machine knows its empty of water.
Many thanksJuly 12, 2017 at 10:52 pm #448892electrofix
I am guessing here and reading between the lines.
it says it has a load sensing circuit on the pump. that means it measures the current to the pump which will be lower when its empty ( like Bosch). it also means a worn pump will have a higher current and fool the electronics. possibly ?
July 13, 2017 at 5:33 pm #448893rolf
Load sensing circuit more like no sense circuit. Looks like I’m going to have to buy my pump raffle ticket and keep my fingers crossed and hope its not the PCB.
I’ll keep you posted.
Roll up roll up !!
Many thanks Dave, really appreciate your help.April 21, 2018 at 10:20 am #448894jrrepair_2000
Hi I have one of these doing the same thing. Did you manage to sort it ?Any help would be appreciated, thanks.
April 21, 2018 at 12:17 pm #448895electrofix
I don’t know what the outcome of this case was but have sent you the same manual I sent Rolf. if your 12Nc number is different then don’t trust the parts list
April 21, 2018 at 1:18 pm #448896rolf
It was a while back, and I struggle to remember what I did last week. But if I remember correctly I changed the pump and it did sod all, customer didn’t want to spend much on it so got wrote off.
Sorry I cant help any more.April 23, 2018 at 6:56 am #448897suedehead1
I assume you have checked for broken wire at bottom of door.
