Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › ADG7540 Not Cleaning
- This topic has 7 replies, 2 voices, and was last updated 16 years, 4 months ago by
webby54.
December 6, 2009 at 4:04 pm #50714
webby54
ParticipantHi,
I have this DW. It’s around 5 yrs old. Today after a 90min wash, the door and the crockery was still dirty.
I’ve cleaned out the filters, topped up the salt and rinse agent and then did another wash, this time with it empty. When finished, the door was still dirty. There were some toast crumbs there from earlier.
I’ve read about pouring hot water from the kettle down into the bottom under the mesh filter. I did this, but the water doesn’t go away. Should it? *it went away when I started a program.
There are no fault lights or beeps. It beeps 4 times when the program has finished which I think is normal, so it *thinks* it’s working I guess.
I put it on rinse and opened the door after 4 mins. The water was above the filters. Also, I put the arms at the 6 o’clock position and at the end of the program they were still in that position.
We’re just about to have a 2nd baby, so we need this thing to work, or get a replacement!
What could it be, and can I fix it? I’m quite handy if it’s physical rather than electrical.
Lee
p.s. I did a thorough clean of all the filters, C tube and spray arms in the summer. All of it was disgusting. Since then, the only build up of dirt/grime on the filters is like a black sooty deposit. Odd, but I thought worth mentioning.
I’ve read the forums here before registering today and I’ve noticed a user called Penguin mention this: http://www.ukwhitegoods.co.uk/help/fix- … -pump.html dreaded part. Looking at the pictures on that page, I noticed the black deposits in the 3rd pic are the same as the grime on the filters.
December 6, 2009 at 8:46 pm #305699Penguin45
ParticipantRe: ADG7540 Not Cleaning
Make sure that the pipes behind the bottom rotor are located properly. If they’re out you lose pressure to both rotors.
Failing that, the pump………..
December 6, 2009 at 8:48 pm #305700webby54
I’m sure the pipe is in good….
So, the pump. Better call someone out I guess.
December 6, 2009 at 9:56 pm #305701webby54
Drain pump or circulation motor?
Cheers Penguin
December 11, 2009 at 6:58 pm #305702webby54
Is this worth repairing for the cost, or just replace it now. It is 5 years old.
Oh, how could I test the motor to confirm it’s kaput?
December 11, 2009 at 11:37 pm #305703Penguin45
webby54 wrote:Oh, how could I test the motor to confirm it’s kaput?
Wait for it to fill, give it a minute, then open the door quickly. You should get slightly wet and see water spraying…..l
Replacement is HERE.
Article about the iniquities of The Big Askoll motor can be found HERE.
December 13, 2009 at 3:42 pm #305704webby54
What if there is a blockage somewhere?
December 14, 2009 at 12:20 am #305705Penguin45
Possible, but unusual on these………. Up to you to strip it down and find out, though.
