adg7550 854275515820 whirlpool d/w
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries adg7550 854275515820 whirlpool d/w
  • #64726
    Galway
    hi everyone,
    looked at this today no power.there is power to on/off switch and power to board but no lights (no budge at all).customer said she does not know how long its broken as the tennant has just moved out and said nothing about it.there is signs of a leak from water level switch in sump and base shows there was a leak.
    i am thinking that this may have fried the board?
    thanks niall
    #357895
    johnmac11
    Re: adg7550 854275515820 whirlpool d/w
    Most of these Whirlpool dishwashers will have signs of a leak in the base and it might be from a previous problem, if you have checked out all the base components it will probably be the PCB, check carefully as these boards are not cheap :eeek:
    IIRC this has a double pole on/off switch, make sure both sides are OK
    John
