ADG957 – Continual Beeping, 30 min flashing, 60 degree solid
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ADG957 – Continual Beeping, 30 min flashing, 60 degree solid
Viewing 1 post (of 1 total)
  • #50066
    andcro
    I see a number of similiar problems posted – but my symptoms are slightly different so would appreciate some help.
    My 7 year old ADG957 dishwasher stopped mid cycle the other day and started to continously beep.
    Now we’ve emptied it out & drained all the water out.
    If I turn it on now (after clearing the fault) It makes a continuous beep, the pump runs and does drain liquid from the machine – but thats it.
    When I open the door the 30 min/40degree light is flashing and the 65 degree (3 plates) lights is on solidly.
    I’ve removed the drain pump, cleaned it – nothing obviously wrong here.
    I’ve checked the heater – 25 ohms – checked it via the cable from the control module – all good there.
    I dismantled the door and checked every wire for a visual break – nothing obvious.
    I’m now lost as to what to do next. If it is a control module – then it is not worth it – but if it is the NTC then it might be.
    Expert guidance gratefully received!
    Cheers,
    Andy
