Adjustable legs for oven?
Home Forums Public Support Forums General Enquiries And Questions Adjustable legs for oven?
  • #96922
    itm60
    Does anyone know where I can buy an adjustable set of legs/feet to support a Belling BI702FPCT double-oven approximately 13cm off the floor?
    #465402
    did the cooker come with legs originally ?
    itm60
    It’s a new one – I’m expecting delivery tomorrow. I’ve called the Belling helpdesk and they’ve told me that it won’t be supplied with legs
    #465404
    don
    Belling double built under ovens like most other manufacturers come with brackets which you fix to the side walls of the base units. Hotpoint ones come with legs and adjustable feet for levelling.
    Don
    #465405
    itm60
    don wrote:Belling double built under ovens like most other manufacturers come with brackets which you fix to the side walls of the base units. Hotpoint ones come with legs and adjustable feet for levelling.
    Don
    Yes the brackets wouldn’t work for me, as the kitchen units on either side of the oven cavity are not as tall as the new oven, and are suspended on legs about 20cm off the floor. If I position the new oven into the old cavity the base will need to sit about 7cm below the base of the existing units (and about 13cm off the floor), so there would be nothing to screw the brackets into on the sides.
    #465406
    if the oven goes any lower it will hit the kick strip below the oven. brackets can be screwed left and right at the bottom of the cabinets
    also are you replacing like for like. Do you have a single or double cavity oven at the moment ?
    itm60
    Yes I was planning on cutting away a section of the plinth below the existing oven. The bottom of the cabinets sit about 20cm off the floor – the cabinets are on legs – so there’s nowhere to screw in the brackets as low as I would need them to be.
    The existing oven is a single – same width as the new oven, but the new oven is 13cm taller.
    #465408
    I assume you have a 30amp cooker supply as dual cavity ovens cannot be plugged into a socket
    itm60
    electrofix wrote:I assume you have a 30amp cooker supply as dual cavity ovens cannot be plugged into a socket
    Yes it’s a 32A circuit
    #465410
    wait till you get the cooker and then read manual
    the closest I can find quickly is
    https://www.manualslib.com/manual/61172/Belling-Bi-70-90-Fp.html?page=31#manual
    they suggest 3 fixing methods depending on situation
    don
    Or you may have to build a plinth for it to stand on 😉
    Don
