admiral AAV 2200AGW motor loose
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries admiral AAV 2200AGW motor loose
  • #74765
    mike100
    Customer complains of jumping all over with small load.
    All springs ok. Only thing that looks odd is motor seems loose. Although it is on plate and it looks like it tensions the belt, should it be loose. Is that what is causing the drum to be out of balance. 😕
    Mike
    #392835
    ELDAR59
    Re: admiral AAV 2200AGW motor loose
    It’s probably the snubber at fault.
    The belt will appear loose when the motor isn’t running.
    The snubber is the plastic disc located at the bottom of the cabinet, just above the drive pulley wheel. Fairly easy repair, involves taking out the drum and turning it upside down.
    Just be careful with the screws holding the snubber in place, they’re pressurised. Loosen them just enough to be able to slide the snubber out.
    #392836
    mike100
    thanks, will try that.
    Mike
    #392837
    ELDAR59
    If you see plastic shavings or dust around the base that confirms it.
    #392838
    mike100
    thanks, any idea of part no. and where to get
    #392839
    EFS
    Useful video here
    http://www.youtube.com/watch?v=NrmhSnksdQ8
    Steve
    #392840
    boselecta
    part number 21002026 only £4 from connect.
    #392841
    burns
    You will need the spring removal tool, but advised theyre no longer available from Maytag. It extends the springs to remove and refit the spings. Easy with the tool not so sure without?
    #392842
    ELDAR59
    Done a few snubber changes and never used the spring tool. Elbow grease yes, tool no!
    #392843
    burns
    Cant imagine doing this without. With its very easy all springs removed from the front even the rear ones. pop the tool in compress and springs off, likewise refitting dead easy. It makes a quick job. But thats the same for any special tool. Struggled with an LG clamp band recently. Then you find theres a tool to facilitate. Shame its about £3000. (Not really but its stupid money).
    (Eldar59, I’ve a full set of Maytag laundry tools which I use every now and then if need anytime?).
    #392844
    ELDAR59
    We have the lg clamp band tools too Steve if you ever need to borrow.
    Also, the suspension leg pin pliers, which are very useful.
    Cheers.
    #392845
    mike100
    Great youtube video, thanks
    Mike
