Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Admiral American top loader
- This topic has 9 replies, 4 voices, and was last updated 16 years, 4 months ago by
Madmac.
December 4, 2009 at 5:58 pm #50685
Madmac
ParticipantBit of a long shot but was wondering if anyone has had any experience working on these machines 😯
They dragged this thing over from the states when they moved here 8 years ago, the machine is around 10 yrs old, couldnt find a mod numb.Anyway, i can pretty much see whats wrong, theres a 200lb spring in a housing at the bottom of the cabinet where the drum shaft bolts to the bottom pulley, this is meant to keep the drum central, along with 6 small springs ( its going mad on spin)
Anyone know if this is a job worth taking on & where the hell to get the bits 😯 (yes, work is quiet :rolls: )Thanks,
Eddie.December 4, 2009 at 6:28 pm #305634BobHope
ParticipantRe: Admiral American top loader
Hi madmack
it will need the snubber changing, not done one for a while now but it can be done without taking that spring out dont tempt removing that spring without the proper tool as it will cause you damage. dont have the part number handy but im sure someone will.
Bob.
December 4, 2009 at 7:08 pm #305635Madmac
Cheers bob, wasnt expecting a reply to this one 🙂 so the bottom spring & the little exposed ones will be ok then? I assume a ‘snubber’ is some sort of bush/friction pad 😯
If its gonna end in me loosing an eye i’ll probably not bother mind :eeek:December 4, 2009 at 8:02 pm #305636BobHope
the snubber is the plastic pad under the washtub / gearbox its about the size of a frizzbe, they are cheap to buy and not to bad of a job.
just google snubber replacment and there is loads of info on how to do it.
Bob.
December 5, 2009 at 7:19 pm #305637Madmac
Cheers mate, might have a play with it 😯
December 5, 2009 at 8:52 pm #305638burns
http://www.partadvantage.com for parts information and use this link for service info:- http://servicematters.com/maytag_librar … index.html
Read bulletin:- ITDL-0020A-B
This will give you a better understanding of stripping it down.Personally I would remove the transmission and replace the snubber then refit the transmission. The white powder in the base is cornflour for friction. Do not lubricate it.
If you dont have the brake spring removal tool leave the pulley in place and this will ensure the spring isnt released.
😆December 6, 2009 at 10:42 pm #305639Madmac
Thanks to you all, still wondering if i wanna take it on.. front loader work has picked up!! 🙂 aw heck, i just might, nice to have something different 😉
December 6, 2009 at 11:14 pm #305640eastlmark
ModeratorRe: Admiral American top loader
burns wrote: The white powder in the base is cornflour for friction. Do not lubricate it.
😆is there a part number for the cornflour or will any old supermarket brand do? have to carry a pack on the van! 😆
December 7, 2009 at 9:43 am #305641burns
There probably is??? but I dont know what it is. Its just cornflour . Dont use too much though you dont want to end up with a pile of pastry after the first wash 😆
December 7, 2009 at 1:14 pm #305642eastlmark
this is a Maytag service engineer shortly after servicing an Admiral washing machine
