Admiral Cap Plus top loader run with just cold water?
Home Forums Public Support Forums General Enquiries And Questions Admiral Cap Plus top loader run with just cold water?
  • #94201
    Monacomark
    I’ve got an Admiral Capacity Plus Heavy Duty top loader (Mod AAV2200AGW).
    Can I just use cold water to run it?
    Many thanks, Monacomark
    #456695
    Re: Admiral Cap Plus top loader run with just cold water?
    all depends if its got a heater or not
    try it
    fill it with cold water and see if it heats it
    if no it need hot
    don
    I cannot see a heater on the circuit diagram or in the parts list.
    This appliance has the two valve fill system so you may need to have both connected to the cold supply in order for the machine to work correctly.
    Don
