Admiral Freezer packaging
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Admiral Freezer packaging
  • #35319
    waynesworld
    Have just bought an Admiral fridge freezer, and have removed all the packaging when it arrived to get it in the house, now we have got it in we noticed it had a plastic covering on it , we started to remove it but have found it very difficult to remove it all and it is leaving little bits behind the side panels, should we have removed this plastic and if so any ideas how we can completely remove it all.Cheers WW. 😕
    #246024
    helo_75
    you could try warming it up with a hairdryer, it helps
    #246025
    waynesworld
    helo_75 wrote:you could try warming it up with a hairdryer, it helps
    Was thinking of something like that , will give that a go .Cheers WW.
    #246026
    helo_75
    best of luck
    problem with the plastic, and you not unique, they press the cabinet together with the plastic on, so the plastic sricks between the joints!!
    if your very carefull, and heat it up, using a very blunt knife or similar,and score down the line, gently, and it will come out
    be careful not to scratch it, thats all
    like i said, ur not unique, most people leave it on, but it does look a hell of a lot better without
    #246027
    waynesworld
    Re: Admiral Freezer packaging
    Had a look at instructions when arrived ,didn’t say anything about leaving on or taking off .It’s a bit of a nightmare to get off,it’s in the joints and behind hinges, but will give your idea a go . Cheers WW.
