Admiral Fridge Freezer GC2227CDFB
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Admiral Fridge Freezer GC2227CDFB
  • #20596
    spidernix
    Hi there
    My Admiral side by side fridge freezer is not working properly. Ice not being made in freezer section (it is cold though but not as it should be).
    The fridge is not cold at all. Any ideas?
    Have tried to find repairman in the repairs@ section but no luck.
    Please help – had to throw lots of food away
    Cheers
    Spidernix
    #187643
    gegsy
    Re: Admiral Fridge Freezer GC2227CDFB
    Hi spider
    Where are you?
    spidernix
    Sunny Worthing, West Sussex
    #187645
    gegsy
    Its more likely that the freezer section is choked up with ice thus not allowing airflow to fridge.
    There are numerous reasons that can cause this from basic ie leaving freezer door open by accident for a period to the intense ie defrost heater/thermostats etc.
    Ideally you need an engineer. Hopefully some UKW engineer may pick up on this.
    Failing that you could contact the manufacturers Maytag for some assistance.
    spidernix
    Decided to defrost unit so turned off and back on the next day.
    Now working like the good old days.
    Thanks for your help. This is the best forum of its kind I have ever seen.
    Regards
    #187647
    gegsy
    spidernix wrote:Decided to defrost unit so turned off and back on the next day.
    If it re occurs after a week then you do have a defrost problem of some sort.
    burns
    If you telephone the call centre on 01737 231 000
    They will arrange for a service engineer to attend, or offer a telephone number of a Admiral Service Agent.
    #187649
    Vikki Glover
    Hello, I have the same problem as spidernix, just wondered if anyone had any help for me. thanks
