Admiral GC2224GEKB
  • #32082
    L8on
    Hi all
    I am new to the white goods industry and already people are bombarding me with problems on appliances. My sister in-law has the above appliane Fride/Freezer (side by side) that freezes everything in the fridge compartment even with the temp set to its lowest. Could it be something lalong the lines of a baffle stuck open or is there more to it than that? Any feedback welcomed, Thanks.
    #233545
    gegsy
    Re: Admiral GC2224GEKB
    Hi L8on
    If you are trade, have you applied for trade access?
    If not then contact site admin without delay 😀 .
    helo_75
    oooh, have had a few of them doin that lately.. not sure what the cure is tbh, tried thermistor and board.. even tried the ‘mod’ of restricting air vents – none of which worked
    anyone got the answer?
    #233547
    ELDAR59
    the ‘mod’ of restricting air vents??????
    whose mod is this then?
    the problem is easily sorted and will be attributable to the damper control in the refrigerator section.
    where are you based l8on?
    #233548
    gegsy
    Ok have moved to trade section as without any response from OP Im sure he is trade 😉 .
    The mod to restrict the venting is BS as alf pointed out, I have no idea where that came from 😕
    The recognised mod to the damper unit is a heater addition and the model and seriel number are paramount to identify correct part for the appliance.
    Hope that clears that up 😀
    helo_75
    erm.. maytag?
    bs it isnt, but then hey, what do i know?
    #233550
    gegsy
    Yea, you only Live Electricals 😆
    helo_75
    and i repair a hell of a lot of em, do i normally post bs?
    #233552
    gegsy
    Did I say you posted BS?
    I said the mod was, no one is having a go helo, chill 😀
    helo_75
    gegsy wrote:Ok have moved to trade section as without any response from OP Im sure he is trade 😉 .
    i am chilled, thanx
    #233554
    gegsy
    Glad to hear it and now you have the answer to the problem you have had with “a few of them” 😉
    ELDAR59
    helo, there’s absolutely no way maytag would have advised you to restrict the air flow from the damper control, so that is most definitely bs.
    #233556
    Has anyone checked whether or not L8ton has actually got Trade Access? They have to ask…..
    gegsy
    Penguin45 wrote:Has anyone checked whether or not L8ton has actually got Trade Access? They have to ask…..
    Did sort of ask in my first post but no reply 😥
    By the sounds of it he is 😀
