Admiral GC2224GEKB american fridge freezer heater O/C
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Admiral GC2224GEKB american fridge freezer heater O/C
  • #34588
    Simon46
    Got this one (my first :eeek: ) with the following symptoms.
    1. Fridge freezing in bottom warm at top.
    2. Frost on evaporator wall and clear ice on floor of freezer compartment.
    3.Water dispensor works for 1 day. icemaker never.
    Found evaporator iced up and heater O/C. Drain blocked solid.
    Wire fallen off evaporator fan 😉 that ducts air upwards into icemaker and fridge. Wire connected all ok.
    No water supply so could not check icemaker.
    Questions are:
    1. When does the icemaker start to kick the ice into the collector bin and when does the rotater churn the ice as no action seen?.
    2.Does the Heater come complete with the in line 104 degree microtemp?
    Maytag e-mailed me a exploded view with 67007091 showing. Very Kind.
    3. Will the heater have blown because the fan was not connected so excessive ice buildup caused it or does the defrost stat 67004757 need to be replaced?
    Many thanks in advance
    Simon
    #243235
    Simon46
    Re: Admiral GC2224GEKB american fridge freezer heater O/C
    Des anybody have info on the shorting links to get the icemaker to work manually?
    Regards
    Simon
    #243236
    roly16
    If it’s the same as the Amana ice-maker, which I suspect it is, then yes.
    #243237
    gegsy
    IIRC, remove end cover off icemaker unit then short H and T out whilst depressing the door switch, this should set it off 😉
    Ice aker wont make ice or let water come in until it has reached -13oc.
    The test points are on the ice maker cap,(the square white plastic you take off)on the inside of the cap.
    Bryan
    #243239
    Simon46
    Thanks all for your help will try that.
    Regards
    Simon
    #243240
    Simon46
    Cust has decided to Buy bags of frozen ice for 80p 👿
    S.
