Admiral GC2224GEKB not defrosting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Admiral GC2224GEKB not defrosting
  • #57726
    Kez
    I have originally changed the compressor but did not fit the original make(danfoss compressor fitted as replacement). Since fitting the compressor the fridge freezer has refused to do an automatic defrost. I have changed the control board and done a forced defrost as per the instruction leaflet attached to the fridge freezer. Under the forced defrost the heater comes on fine. I am now wondering if fitting a danfoss compressor has caused the defrost problem as I understand that the defrost is worked out by accumulated compressor run time. Does anybody know if this could be the problem or has anybody fitted a compressor of a different make to this model without further problems. Thanks in advance I hope! Cheers Kez
    #332100
    ELDAR59
    Re: Admiral GC2224GEKB not defrosting
    hello kez, the compressor shouldn’t be a problem.
    you’ve changed the board, so i’d be looking at the defrost stat.
    cheers.
    #332101
    Kez
    Cheers dont suppose you would have the part number by any chance? 😀 Thanks Kez
    #332102
    johnsdad
    67004757
    #332103
    Kez
    Have spoken to the engineer again and he tells me he has already fitted a new one of those, Any other ideas please? Would the positioning of this defrost stat cause any probs if it was fitted in the incorrect place? Cheers Kez
