Admiral GC2224GEKW damper
  • #66292
    boselecta
    SN: 10398832GE
    This fridge freezer is freezing in the fridge. I believe the damper to be faulty part number 67006251.
    I have read on this forum some of you fit a heater kit as well, what is the part number for this part?
    thanks
    #363728
    burns
    Re: Admiral GC2224GEKW damper
    Hi.
    The heater kit is required when in a humid environment. Moisture settles on the damper door and condenses then freezes, This usually hapens early on in the life of the appliance unless something has changed i.e resited, double glazing or a range cooker fitted etc. Anything to change the immediate humidity.
    If you are replacing the damper a heater kit wont go a miss but check also that the door hasnt dropped like the last one I attended. It had a few dampers fitted by the original engineer, but they missed the door had droped allowing warm air to enter. Caused the same problem though.
    #363729
    boselecta
    Thanks burns
