Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › admiral GC2227CDFB FRIDGE FREEZER please help
- This topic has 13 replies, 3 voices, and was last updated 13 years, 7 months ago by
steve-mport.
August 26, 2012 at 9:07 pm #71157
steve-mport
Participanti have an admiral GC2227CDFB works for an hour then will trip the electric any advice welcome thanks
August 26, 2012 at 9:25 pm #380168spimps
ParticipantRe: admiral GC2227CDFB FRIDGE FREEZER please help
Obviously an electrical short.could be motor or defrost element.
You will need an engineer with a meter (meggar) to isolate/identify the component responsible,August 26, 2012 at 9:27 pm #380169steve-mport
what i have noticed is the compressor does not shut off runs constant and gets very hot
August 27, 2012 at 10:35 am #380170steve-mport
any1 able to help
August 27, 2012 at 9:09 pm #380171ELDAR59
if it only runs for an hour then it may not be running long enough to turn off on it’s own.
main causes of a fridge like this tripping the electric are defrost heater and compressor.
with the information we have so far, it could be either.
you could unplug the heater to see if it tripped after an hour. if it still trips then it’s likely to be the compressor.
a compressor change is a specialised repair and you will need an engineer.August 30, 2012 at 8:14 pm #380172steve-mport
where is the defrost heater located to unplug
August 30, 2012 at 10:16 pm #380173ELDAR59
In the freezer section, behind the back panel.
August 31, 2012 at 10:23 pm #380174steve-mport
done that now nothing works just the lights in the fridge and freezer
September 1, 2012 at 7:57 pm #380175ELDAR59
It’s obviously in defrost mode then now.
Keep it on and it should fire up after about 20 mins. Alternatively you could advance the defrost timer to run mode.
If its not tripping the electrics and you’ve taken the heater out of the circuit, then it looks like you’ve answered your own question there.September 8, 2012 at 11:10 pm #380176steve-mport
well changed the grey coin thing in the compressor start relay fridge working now
September 9, 2012 at 9:16 am #380177steve-mport
well now the freezer working spoton just fridge not cooling and ideas
September 9, 2012 at 3:32 pm #380178ELDAR59
The fridge works directly from the freezer. If the fridge isn’t working then you have another problem.
Is the evaporator fan running in the freezer?
Tricky to say over the net, how long has the fridge been running since you changed the disc in the relay?September 9, 2012 at 6:13 pm #380179steve-mport
sounds like there is a fan running inside the freezer the fridge was working from thursday night and all was working fine until notitced it wasnt cool in the fridge yesterday freezer part seems to be working fine
September 9, 2012 at 8:58 pm #380180steve-mport
wheni turn the dial down to zero in the fridge fan stops as soon as i move off zero fan starts again just dont no why fridge aint cooling
