Admiral SAC224GB – S/S side by side – Freezer not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Admiral SAC224GB – S/S side by side – Freezer not working
  • #58906
    1670will
    Hi, would be grateful if anybody can help.
    Bought this reasonably expensive fridge thinking it would be good quality in April 2008.
    The freezer is now not working properly and is not freezing the contents.
    The fridge does seem to be cold and working.
    Took all the food out and the grill at the bottom back of the freezer appears to be really quite warm and almost smells like its burning slightly.
    Any ideas what is wrong and how it can be mended ???? or who to get to mend it in London if I cant mend it.
    Any help much appreciated.
    Will
    #336074
    Re: Admiral SAC224GB – S/S side by side – Freezer not workin
    Defrost heater is virtually the culprit.turn it off for 24hrs with both doors left open and then restart it…if its not defrosting then after about 7-10 days the freezer will start not working again.
    Bryan
    #336075
    ELDAR59
    hi will, mixed signals here i’m afraid. you say that the evaporator is warm? (the unit in the freezer behind the back panel) yet you say that the fridge is ok?
    the fridge takes it’s ‘cold’ directly from the freezer and so it’s impossible for the fridge to be ok and the freezer be warm.
    if the defrost heater has stuck, then it looks like a pcb fault.
    there’s a poster on here by the name of old lonely who should be able to help you.
    perhaps worth a pm to him?
    cheers.
    #336076
    1670will
    Hi Bryan
    Not sure I understand your reply, the problem is that the freezer IS defrosting.
    Do you know what problem with defrost heater might be ?
    thanks
    Will
    r600a wrote:Hi
    Bryan
    #336077
    1670will
    Hi Alf
    Thanks for your comments, I here what you say about the fridge getting its chill from the freezer. I am defrosting the entire fridge for 24hrs and will turn it all back on and see what happens.
    Re the heater, are you suggesting the defrost heater might become stuck on ?
    Can this occur due to some kind of physical problem, ie iceing up inside the fridge somewhere too much or a broken sensor, or is it always an electronic problem with the PCB ?
    I will try and contact old lonely as well.
    many thanks
    Will
    alf_uckem wrote:hi will, mixed signals here i’m afraid. you say that the evaporator is warm? (the unit in the freezer behind the back panel) yet you say that the fridge is ok?
    cheers.
    #336078
    ELDAR59
    will, defrosting the fridge will only alleviate the symptoms for a while, if it’s iced up that is.
    obviously if it’s warm, then there won’t be any ice to defrost.
    if the heater is sticking on, then it will be the pcb.
    we can only speculate and talk in terms of probability, but old lonely will be able to sort you out.
    he’ll either be able to repair it, or he’ll know someone local to you.
    cheers.
    #336079
    1670will
    How do I contact old lonely ?! I used the search function but it comes up with nothing ?
    thanks
    Will
    alf_uckem wrote:will, defrosting the fridge will only alleviate the symptoms for a while, if it’s iced up that is.
    cheers.
    #336080
    ELDAR59
    will, mike is on..
    #336081
    We cover the north / west london area.
    service@fffrservices.co.uk
    Bryan
