Admiral Tumble Dryer
  • #36414
    S1MON
    AYE2200agw 10620225zu
    Been to this m/c this morning with a timer and door switch as it would not start. Fitted new timer as old one did seem to be engaging when you pressed the knob to start. Fitted new timer no change.
    Got 240v at the timer, but nothing at the door switch. Checked the wiring diagram again and there is a thermal fuse listed. Any ideas were it is on the m/c as i had it apart and could not locate it. Also any other ideas why else it wont start as it seems a releatively simple m/c.
    Also when i put it back together I could get the belt to say on th pulley???
    #250910
    Re: Admiral Tumble Dryer
    The thermal fuse is on the heater, comes as a kit 4401067322 £27.89!
    #250911
    S1MON
    is it likely to be that causing the thing not to start at all
    #250912
    yes, but check all the airways, especially under the filter in the front panel, to find out why it has tripped in the first place. Easy to check and temp by pass the toc to find out. One big one on top of the heater and a small one hidden on the side of the heater. Both should be closed circuit IIRC. It will be the small one that will have tripped but the kit contains both. I have the kit in stock if you need it.
    #250913
    S1MON
    I can get hold of it throu work cheers……. Did find a blockage in the frot vent when I tok the front off and the hose is restricted….
    cheers
