ADMIRAL USA MODEL AC2224GEKB – LIGHTS ON NOBODY AT HOME!!!!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum ADMIRAL USA MODEL AC2224GEKB – LIGHTS ON NOBODY AT HOME!!!!
Viewing 15 posts - 1 through 15 (of 18 total)
  • #44597
    Westie-Lady
    Having problems with freezer defrosting for no particular reason even the ice making facility is not making ice etc. Can anybody point my husband to any possible problem what could be wrong. We don’t want to call an engineer out straight away, he would like to check all the necessary things himself first.
    We have turned off the fridge/freezer off for approx 15 mins and tried rebooting back up but still to no avail. The freezer does sound as though it is working ie. lights are on and even sounds as though its all working.
    The ice maker is taking in the water but not making ice.
    The fridge is working fine.
    24 hours have now gone and just got up from bed and now the fridge is not working. The lights are working and it sounds as though everything is okay but unfortunately its not.
    MAKE: ADMIRAL
    MODEL: AC2224GEKB (SAL224GB)
    SERIAL NO: 111374974JL
    Any help would be much appreciated.
    Many thanks
    #281552
    ELDAR59
    Re: ADMIRAL USA MODEL AC2224GEKB – LIGHTS ON NOBODY AT HOME!
    hello, if you open the fridge door, can you hear the compressor (motor) kick in, only to go off when you close the door again?
    #281553
    Westie-Lady
    Yes you are right when we open the fridge door the compressor kicks in and goes off when the door is closed.
    You obviously got a good idea what is wrong by the sound of it!!!!
    The fridge/freezer is only 2 years and 2 months old so I suppose its just outside the warranty period.
    Look forward to your reply.
    Many thanks
    #281554
    ELDAR59
    it’s a simple one really.
    the problem lies with the circuit board which is in the fridge at the top where the digital display is.
    you need a new control board for the fridge.
    #281555
    Westie-Lady
    Would you know where we could buy one from – any tips for getting at it etc.
    Thank you so much for replying so soon we are off on holidays shortly and my parents are staying so didn’t want to leave them with this problem.
    #281556
    MAYTAG HAVE A FIVE YEAR PARTS. U WILL ONLY PAY FOR LABOUR £125
    #281557
    ELDAR59
    maytag have a five year parts???
    on a compressor maybe, other parts definitely not.
    labour £125? it was £135 last year, it’s now £150.
    #281558
    machineman
    ANYONE know the part number for this mod
    DAVE
    #281559
    ELDAR59
    W10165748.
    #281560
    oldlonely
    Hi Alf,
    W10206638 is an updated board jazz 15 code 28.
    O’l
    #281561
    machineman
    WE fitted that board .had trouble inserting code ,it would not accept the info from rating plate but accepted the code before. seems to be still working ,fingers crossed
    oldlonely
    Dave,
    Each board has a different code, true, some will accept earlier codes, but the latest board jazz 15 code 28 regardless of what’s on the rating plate.
    O’l
    #281563
    spudder007
    Hi Machineman
    When you say you fitted ‘that board’ what one did you fit i.e. what part number? I am confused with reply (sorry).
    Also, you mention a code. How is this input. I am not a fridge engineer but do repair electronic devices.
    Also, where did you buy it from?
    Thanks in advance
    #281564
    machineman
    Part number W10206638 purchased from electrue part
    the procedure is a bit long winded but easy to do
    open fridge door close door switch
    press freezer temp down 3 times within 10 secs
    release door light
    display shows P+E
    confirm entry freezer button once
    display 0+0
    take code from bar code i think mine was 28
    press freezer button up until 2 is reached
    press fridge up until 8 is reached
    press freezer buton down until it flashes
    Hope that helps .
    spudder007
    Hi Machineman
    Thanks for getting back to me so soon.
    I will give it a go.
    Cheers
