ADP 8224 Reset Codes
  • #5121
    Can any help. I need to reset the machine after the door was opened befor the cycle was finished. I think you need to hold down buttons. Reset method would be good right now.
    Andy 😯
    #109052
    Re: ADP 8224 Reset Codes
    Andy,
    I am not certain if anyone on this site can help you there. Better contact MFI for a copy of the users instruction book if you have lost yours that is. I am sure the book would give you the information about resetting?
    With other brands, they often ‘Highlight’ which two buttons are required for resetting by putting a dot/dash or similar mark under the relevant buttons.
    Sorry I cannot be more help?
    I open my machine all the time mid cycle, why does it need resetting?
    Jo.
    #109054
    Thanks for the info. The user book does nothing and I have managed to hold all 3 buttons down to get it started again. After the cycle it locks up again!! E3 code but every thing is hot.
    #109055
    shane
    Andy G wrote:Can any help. I need to reset the machine after the door was opened befor the cycle was finished. I think you need to hold down buttons. Reset method would be good right now.
    Andy 😯
    Firstly switch the power off on the control panel. Then hold down the programme button while switching the power back on. A single bleep should be heard. Any gremlins should now be bannished.
    #109056
    Afternoon,
    Just received my control panel back from QER and just fitted it. I too got the E2 message and worked out how to reset it.
    Dishwasher is on at the moment but wont no for another 20 mins or so until it starts to heat up. Keeping everything crossed!! Ive had enough of the damn thing.
    I couldnt get one of the screws in properly on the control panel, anyone know what size they are so i can get another, flippin thing. Ive got it working and i put all the decor door back on, fool! ive got to take it all to bits again when i get another screw.
    A big thanks to QER and again to Martin, there service is fantastic and would recommend them to anyone. Works out a fraction of the cost of replacing bits n bobs.
    Tara for now,
    Lolly 🙂 🙂 😉
    #109057
    Thanks Shane for this bit of info, I have tried it on my delinquent machine and it has run a whole cycle without quitting, and no E2 code appearing at the end. If it can do this again tomorrow it will be allowed back into the kitchen and the spare one will go back into retirement till I find a new home for it!
    Jo.
    #109058
    Machine is now back in place and behaving perfectly. I won’t be opening the door mid cycle anymore…
    Jo.
