ADP 8242 Error Code E2
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ADP 8242 Error Code E2
  • #14940
    trukkie
    Tried a search for E2 but nothing showed so …
    can someone give me some pointers on what to do about this particular error ….cheers
    Basic symptoms: machine starts cycle, gets halfway through rinse then
    quits, empties beeps and shows an E2
    Machine is 3 years old
    Any info appreciated
    ta
    #161395
    gegsy
    Re: ADP 8242 Error Code E2
    Hi trukkie
    Look at the sticky at the top of this forum 😉
    trukkie
    Cheers greg 😳
    did a search for E2 but it returned 0 …
    time to get the hose out !
    #161397
    gegsy
    Its actually a “Sticky” at the top of the dishwasher forum listing viewtopic.php?f=33&t=8046
    greg
    #161398
    There’s also the artilce that that nice Penguin wrote HERE
    There’s lot’s of good stuff in the “Articles & Help” section. 😉
    trukkie
    Cheers kwatt
    Last question … honest
    does anyone know where the transfer tube is on an ADP 8242 ?
    Had a look into the sump – no black flap
    just a hole to the left and can feel an inlet under the front bottom edge
    of the sump – could be ?
    ta
    #161400
    gegsy
    Once you take the filters out, in the recess, the black flap is un missable, unless it is missing 😯 I have seen this and would cause this fault 😉
    Obviously if its missing you wil be left with a hole approx diameter of the old halfpenny.
    Hi Ken, hows Del :wave:
    trukkie
    Oh dear !
    looks like I’m missing the black flap then coz there’s nothing
    black in the bottom of th sump – all nice white shiny plastic !
    thanks for the info greg
    off to the spares dept âž¡
    cheers
    #161402
    trukkie
    Hi all,
    Well I finally got the dishwasher apart and found the pressure tube which runs from the sump to the pressure switch (loops over distributor)
    was completely split in two.
    Not sure if it has ruptured or a mouse! has got at it.
    Anyway does anyone know where I can get a replacement pressure tube
    cheers
    Trukkie
    p.s big thanks to P45 for the help
    #161403
    Bit of windscreen washer tubing from Halfords is cheapest and quickest option.
    Or if you need the right bit an email to spares@ukwhitegoods.co.uk will get it sorted. 😉
    trukkie
    Top tip !
    cheers 😀
    #161406
    trukkie
    IT WAS A MOUSE !!!!!
    found loads of mouse droppings and bits of rubber in the bottom tray
    Perhaps Penguin could update the E2 failure page with mouse sabotage 😆
    Cheers
